Old 12-13-2016, 10:54 PM   #143 (permalink)
Stubby79
Stubby79's Avatar
Firefly EV - '98 Pontiac Firefly EV
90 day: 107.65 mpg (US)
Little Boy Blue - '05 Toyota Echo
90 day: 33.35 mpg (US)
BlueZ - '19 Nissan 370Z Sport
90 day: 17.19 mpg (US)
Originally Posted by LittleBlackDuck View Post
post up a sketch of how it is wired. sounds like the ground that you are using for power to the Link 10 has some ground offset from the negative side of the main battery. Just for giggles, can you power the Link 10 from a battery that is not connected at all to the car? I think that this will fix the issue if my gut feel is accurate.
Simon
I'm bench testing. And powering from a completely separate battery, then through the isolators. There is no electrical connection between the power supply and the substitute battery pack. And I didn't have the voltage sensing wires hooked up at the time, so the common ground that the Link 10 and both batteries are supposed to have isn't there.
I suppose that could be the issue. But that seems weird to me. It's just reading amps by the voltage difference between one side and the other of the shunt, a dead simple thing in my mind.
I'll hook up the voltage sensing leads, and see if being "grounded" will affect it in any way. Thanks.
