I'm going to look into the specs and see the different characteristics between the oils. Do you happen to know the oil certification required to be compatible with the Toyota oil? The revenol had a LOT of compatibilty since it was SAE certified as well.
Revenol ATF T-WS is compatible with the Toyota world standard ATF and is a gen 5 type oil.
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
