Old 12-16-2016, 09:08 AM   #1 (permalink)
redneck
Brilliant...??? or Scam...???
Brilliant Light Power
Electrical power from water fuel
Brilliant Light Power, Inc. has developed SunCell®, a 30 pound Table Top Electrical Generator capable of producing 125 KW of Power. SunCell® Energy Density conversion yield is staggering for it's small size and weight, 100 times greater than the equivalent amount of high-octane gasoline; enormous energy density.
brilliant light’s suncell® has produced millions of watts of power at a power density that is significantly higher than that of any other power source. The nonpolluting power-producing suncell® catalytically converts h2o-based molten fuel injected into ignition electrodes directly into brilliant light-emitting plasma power. The suncell® plasma temperature is adjustable emitting a solar-like spectrum of light, but at extraordinary power equivalent to ten’s of thousands of times the sun’s intensity at the earth’s surface. Optical power is converted directly into electricity using concentrator photovoltaic cells (solar cells), very high-power, high-efficiency cells that are commercially available. Patents are filed worldwide.
They are planning field tests in 2017 and a commercial launch in 2018.
If true...
This could change life as we know it.
So.
