Originally Posted by cfg83
b(o)bjsw10 -
What if you Rhino-lined the interior? I think you would definitely reduce the risk of getting cut on sharp parts. Mayyyyybe the noisy rattles would also be reduced. But, would the Rhino liner add as much weight as you removed?
CarloSW2
Glad you liked the switch. Thanks.
Rhino Linings weighs about 11-12 lbs/gallon. It would take roughly about 2 gallons to spray interior, it comes out fast and is alot thicker than paint. So it would weigh approx. about 20-25 lbs more with Rhino. More than the plastics I would think.
But the Rhino would really protect more against rust and deaden the noise. It is a non-porous substance so will not let moisture get to metal.
Where I work is actually a Ziebart dealer too. So I can get rustproofing for cost. There is 4 businesses in one building all ran through my shop. Gets kinda crazy sometimes.
Ambulance remounts, RV dealership, Rhino Linings, and Ziebart we also do any automotive accessory you could think of, probably why I am bald.
