Old 12-16-2016, 12:48 PM   #84 (permalink)
RoadCyclist
Delta Flyer - '94 Honda Accord
90 day: 31.31 mpg (US)
Best tank!
Well, I think minimum throttle/ high Hg pressure is the way to go! I just recorded a record tank of 35.5 mpg. I was also using 89 test fuel, which I suspect helped but I will have to do some more testing to find out.
Now onto another question. I have a 3 or 4 inch air dam. I made a cloroplast forward undertray but have not put it in yet. Would it work better mounted: A. Without the air dam B. Attached to where the air dam is attached or C. Attached to to bottom edge of the dam, which might be flimsy?
Second and final question: I made a lower grill block and mounted it "set in" about 2" from the bumper in the grill. I'm wondering if making it flush with the bumper would be better, as then it would help flow air around the bumper instead of formimg a high pressure cavity in front of the air inlet?
