Old 12-16-2016, 08:54 PM   #331 (permalink)
Bill the Engineer
Bill the Engineer's Avatar
Even so, I may still need to make some bracket modifications to some parts that stick up high near the Prius v brake fluid reservoir. Square peg into a round hole type of problem. Worst case, it can protrude up into a hollow hood tach casing.
In addition, since the Firebird hood is narrower than the Prius v hood, I will also need to make a small portion of the left front fender removable to access the Prius v fuse panel. Not difficult, but necessary.
Bill the Engineer
The Following 2 Users Say Thank You to Bill the Engineer For This Useful Post:
aerohead (06-19-2020), Xist (12-21-2016)
