Old 12-17-2016, 02:45 PM   #32 (permalink)
ksa8907
Volt, gas only - '12 Chevrolet Volt Premium
90 day: 38.02 mpg (US)
Volt, electric only - '12 Chevrolet Volt Premium
90 day: 132.26 mpg (US)
Yukon Denali Hybrid - '12 GMC Yukon Denali Hybrid
90 day: 21.48 mpg (US)
Where I work we use more power every day than a 2 story 2400sq.ft. house with a family of 5 uses in 12 years.
And they are not shy about spending several million dollars to lower the bills. 3 expansions to conserve natural gas, power but mostly to save water, all no less than 10 million each.
The 700hp ammonia compressor motors draw up to 1,100 amps of 480 on start up and they cycle on and off all the time.
500hp motors draw 500 to 700 amps depending on if they are driving compressors or turbo fans.
We don't use batteries.
Bank maintenance would cost more than it would save.
I work for a NG distribution company where i work directly with meters and consumption data. We have several ethanol producers that use around 400,000 cubic feet of gas per hour, typical house furnaces use 100 cubic feet per hour and run intermittently. A small efficiency increase goes a long way.
If these chargers are going to deliver 350kw, they pretty much have to be installed near hv transmission lines. Even at 7kv street lines it would pull 50 amps if it were a perfect conversion.
The Following 2 Users Say Thank You to ksa8907 For This Useful Post:
aerohead (03-09-2019), Xist (01-08-2017)
