but first, i'll build it for tractor use. If the design is good enough, i'll convert a Ram van or a Chevy Astro for wood gas- with automatic gas lambda adjustment, Quick-autostart and pellet-feeding system in the future
The engine must be tuned with higher comp and maybe introduce a supercharger, it improves the efficiency
If you don't make any mistakes in your life,
life itself will be a f*ckup.
With Volvo to Valhalla and back!
