Originally Posted by Bill the Engineer
Even so, I may still need to make some bracket modifications to some parts that stick up high near the Prius v brake fluid reservoir. Square peg into a round hole type of problem. Worst case, it can protrude up into a hollow hood tach casing.
Have you looked at other Prius reservoirs, in case they are wider and lower? I know you are limited in how low you can move some of them and still be useful, but that brake reservoir looks like it could lose at least 2 inches in height IF you found a comparable volume one that was wider and lower. To coolant one could possibly be moved to a completely different location.
Or you could use a widened cowl induction hood scoop ;-)
In addition, since the Firebird hood is narrower than the Prius v hood, I will also need to make a small portion of the left front fender removable to access the Prius v fuse panel. Not difficult, but necessary.
What about rotating the fuse panel outward 90 degrees, and making the removable panel in the inner fender skirt?
