Old 12-19-2016, 01:42 PM   #31 (permalink)
gumby79
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
90 day: 23.4 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 2×4 AUTO
Pickups
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
90 day: 20.24 mpg (US)
Jona Allison aero - '91 Dodge Ram D-250 Le
90 day: 20.76 mpg (US)
Rules interpretation
5.2.12 No streamlining may be attached to the rider.
..... this makes my prvious tail/butt fairing useable, unless it is attached to the tail of the bike.
5.2.12.A. All fairings must be made of plastic, fiberglass or carbon fiber.
.... Theas are the materials you can use for your mods. Except parts associated with drake cooling and wind deflectors.
5.2.11 Fairings must be mounted in at least three locations. The front wheel
must be clearly visible from both sides except for the portion covered by the fender. The rider must be visible from the side and above, while in a normal riding position, and transparent material may not be used to allow for such visibility.
....I read this to mean the entire front wheel/tire can be covered by a 1pice finnder
5.2.4.C. Aftermarket brake cooling ducts or wind deflectors may be made of metal providing the design does not pose a safety risk to any competitor.
Final approval of unit rests with the Tech Inspector. (each and evry race)
A 1 pice finnder would combine both 5.2.11 and 5.2.4.c
5.2.10 Rear fender or seat must extend to the rear of a line drawn vertically at
the rear axle.
They state a minimum... no maximum. Added length is a compromise between reduced aerodynamic drag and increased Rolling Resistance coefficients. Use Aerodynamic & rolling resistance, power & MPG calculator - EcoModder.com to figure out how far you can go and see a benefit.
Gumby Stay Flexible.
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
