Old 12-19-2016, 02:17 PM   #5 (permalink)
Daox
I'd heat your gas line to keep it liquid under pressure, and as it injects the fuel, it vaporizes as it comes out. You'll have to work to the lowest common denominator as you do the temperature and pressure calculations to work with the lowest combustion temp / vaporization temp component in gasoline.
The Following User Says Thank You to Daox For This Useful Post:
Xist (12-21-2016)
