Old 12-19-2016, 04:32 PM   #9 (permalink)
sallen
VW GOLF - '96 Volkwagen Golf MK3 GL
90 day: 50.21 mpg (US)
Commute scoot - '95 Suzuki AE50 Style
Last 3: 70.4 mpg (US)
The German - '99 Mercedes W202 C200 Classic
90 day: 27.65 mpg (US)
Thanks again for the quick turnaround.
I've added the VSS and injector params to get it into the ballpark and will calibrate at the end of the tank as per the instructions here:
Mpguino calibration - EcoModder
Thanks again for all your help, the MPGuino now looks like it will be very useful.
A couple of observations on the new version:
- The uSec/Gallon default value was waaaaaaaaaaay low - like 703 or something, so I used a calculator and input the loooong number for some injectors in a similar model;
- I see there is both mL/min and uSec/Gallon and they are independent - does it use both, or one?
- On the old version's instant MPG, I was getting infinite "- - - MPG" down to 1600rpm, now I get a larger number (100 - 200mpg) or a fixed 0.49MPG in place of the - - -, perhaps some of that is the new settings.
I'm not driving much over Xmas so I will calibrate in Jan and hopefully all will be good.
Thanks again,
Will you recoup money spent on mods in fuel saved? see my spreadsheets here
