Old 12-20-2016, 12:19 AM   #28 (permalink)
RustyLugNut
This is serious.
Originally Posted by davelobi View Post
huh? how are "they" starting the burning 30 degrees btdc? Engine would stop, almost like a hydro lock, if you set ignition to spark (burn the gas) at 30 deg btdc. Imagine the power of the starter motor that would be needed to crank that puppy up. Ever advance timing a little too far? = bucking the starter motor.
You are trying to correct erroneous points and yet have no knowledge of such a basic principle as ignition lead time? It undermines your position.
The Following 3 Users Say Thank You to RustyLugNut For This Useful Post:
elhigh (01-13-2017), Shawn D. (01-11-2017), Xist (12-21-2016)
