The new Nissan Titan XD has been released for a while now with the new Cummins 5.0L Turbo Diesel, but it hasn’t really made the splash that many expected. Part of the reason is that it doesn’t seem to get the MPG many expected, and most reports on the internet are indicating anywhere from 16-20 MPG. While not that bad, this MPG isn’t really all that good and not the 25+ many expected.
Here are some things I noted about the truck relevant to MPG:
Engine-From an engine standpoint, it is hard to argue that the 5.0l Cummins is fairly technologically advanced, but along with the new technology comes the baggage of the newest emissions requirements. I am sure there are some MPG being left on the table to reduce emissions, the most apparent of which is when the vehicle goes into regeneration of the exhaust.
Transmission- No manual transmission is offered, instead you get an Aisin 6 speed automatic with the diesel. This unit is heavy duty, with a double overdrive topping out at a ratio of 0.634 : 1. For an automatic, this isn't that bad.
Axles- The differentials are fairly heavy duty. The rear is an AAM semi-floating unit with six lugs. Gear Ratios available are 3.916 and 3.357, and it appears Diesel versions default to the first and gas versions default to the latter.
CD-I haven’t been able to find a solid drag coefficient for the new Titan XD, other than the ambiguous “10% less” than the previous model. The previous Titan was credited cd=.44, which at 10% less would imply the Titan XD is cd = 0.396 or roughly cd = 0.4 since I assume the significant digits of “10% less” are one at the best.
Area- Using the base model “S” 4x4, the published width of the truck is 79.5” and Height of 78”. Using the 80% rule, that puts area around 34.5 ft^2, for a cd*A of roughly cdA = 13.6.
Weight- This thing is heavy! Curb weight varies between 6700 and 7500lbs, with a base model 4x4 right around 7,000 lbs. GVWR is just under 9000. That weight is right up there with my 2001 2500HD with the 8.1l big block Allison 4x4. This unit is basically a commercial chassis built with commercial parts, resulting in one heavy truck.
Here are some ideas I had of how a Titan XD owner could improve their MPG up to where it “should be.”
Aerodynamic bedcover. The area of the truck is huge, and with no easy way to pare that back, attacking the not so great cd number would be the first step to getting this thing to respectable MPG numbers. See attached AST-II overlay for ideas.
Underbody smoothing. Other than the bed, the only other part of the truck yearning for aero attention is the underbody. The rest of the truck seems fairly well designed aerodynamically. Watch out for the huge exhaust system though, as you don’t want to trap any heat especially when the exhaust starts to regenerate.
Differential Gear swap- If you have reduced the aero drag, you may want to swap the differential gears if you started off with the diesel standard 3.916 down to the gas standard 3.357. These three items together would really help highway driving.
Weight reduction- I don’t know exactly from where you would lose it, but the huge curb weight would be a boon to any stop and go city driving.
Stick Shift- This would be the hardest thing suggested, but swapping in a handshaker would allow for much better control and driving style of the vehicle. A ZF6 or similar would be a good choice, and obviously lots of computer programming and custom fitting would have to go along with it.
Thoughts or ideas?
![](http://ecomodder.com/forum/attachment.php?attachmentid=21075&d=1482246157)
