What is the new and old rpms @60mph? 1)gear chang 2) trans swap?
---port match the ehxsost manafulld on both sides .
Wrap it ... I used the extra thick wrap 1.5 rolls for man +hot side ehxsost...
Exhaust Heat Wrap
And T3 Turbo Blanket..
Have the man. hot tanked (to de rust) and 2000°+ ceramic paint.
This dropped my under hood temps to under 200° can stop at the top of a 7mile grade pulling 1000°f EGT(wide open ) pop the hood and hold on to the man. With out 3rd degree burns. The wrap reduced my 1psi point by 100° (from 600° to 500° ) = more efficient turbo. This drop was an across the bord shift.
kafer65. I make the same recommended ehxsost mods for you...
Keep the after cooler. Add a late 1st gen inter cooler/ radiator (early 1st gen too small for intercoolers per dodge/ cummins) put the aftercooler on a separate radiator ( stock is engine coolent180° intake charge =15% reduction in power from un burned fule per Cummings )my late has 15% smaller injectors and the same 160hp /400tq only difference is injectors and IC Vs aftercooler
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
![](http://ecomodder.com/forum/fe-graphs/sig8842a.png)
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
