Old 12-20-2016, 02:43 PM   #87 (permalink)
gumby79
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
90 day: 23.4 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 2×4 AUTO
Pickups
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
90 day: 20.24 mpg (US)
Jona Allison aero - '91 Dodge Ram D-250 Le
90 day: 20.76 mpg (US)
? Could you use an ohms type gage sending unit as the control circuit?
Explained
The servo uses a reastat for position . A '70'sGM temp sender is (if I remember correctly) 30ohms cold 120ohms hot. Or some variation of that. Put the sender in line with the position reastat. Thie would skue the position, causeing the arm to move , and the servo would think it was just holding the single point . Factory is centered.
The compleet logic /power circuit would consist of ; BEC (battery elimination circuit capable of 1 to 6s lipo in and programmable out,6v stock)servo and resistor based temperature sender.
?am I on track?
A basic bec will handle 25amps at up to 24v=6s lipo=4.2/cell@ full charge nominal .
High doller 50amp and 52v nominal.
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
