Old 12-20-2016, 03:54 PM   #37 (permalink)
Grant-53
Good stuff. Some organizations limit the height of the tail box so you might want to check into that. If your back is horizontal with a slight curve, be sure there is no gap between you and the tail. A top view should look like a teardrop to minimize air flow separation. One trick we use on our pedal bikes is to streamline the spokes on the front wheel and use smooth disk wheel covers on the rear.
