Originally Posted by aardvarcus
Weight- This thing is heavy! Curb weight varies between 6700 and 7500lbs, with a base model 4x4 right around 7,000 lbs. GVWR is just under 9000. That weight is right up there with my 2001 2500HD with the 8.1l big block Allison 4x4. This unit is basically a commercial chassis built with commercial parts, resulting in one heavy truck.
Isn't that even heavier than your 2500HD? Seems like a lot of heft for not a lot of haul.
