Old 08-13-2008, 01:33 PM   #14 (permalink)
cfg83
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
chilimac02 -
Originally Posted by chilimac02 View Post
I'm VERY interested in the how's of leaning A/F mixture. I have a scangauge II, will it display A/F mixture? I've been noting when closed loop vs. open loop occurs. My car stays in closed loop up to about 90 Load, unless the throttle position is over about 75%.
The article you mentioned discusses cruising in open loop... My car doesn't do this. Does that mean that I cannot modify the A/F mixture at cruising speeds (55mph)?
You may be able to display the voltage of the 02 sensor using the X-Gauge option, but you will need to know the access code for it. However, I have not seen a specific example of anyone doing this, and the 02 sensors flips back and forth so much that you would need a refresh rate that is faster than the ScanGauge's "4 digital gauge" option. Sooooo, it may not be practical.
CarloSW2
American Solar Energy Society
