Yeah, you don't need to run the engine until the battery is depleted. I messed with trying to use hold mode to use the battery at optimum times, but most of the time I'd get home with a small amount of unused battery.
The think the Volts engine is actually designed for frequent start/stops and low engine temperature operation. I remember reading some differences to a typical engine, but I can't find it now.
