Ways to slow without touching the brakes. And what a diverter valve is.
In the60's, 70's, and 80's gas v engines had a diverter valve it 95% blocked the passenger ehxsost manafulld. Rerouting the hot gas through a passage under the carburetor and out the drivers side . On a 61' GMC 305ci V6 the valve had a bimetal spring to open it ,hence not full blockage. My 79 Chevy K-20 with a 350ci V8 was normally closed vacuum actuated via a thermal valve in the coolent . I had the vac line brake causing the spring to close the valve . At 70mph the passenger manafulld was glowing in direct sunlight, well over 700°f. Let it cool then wired it open as my Edelbrock Rpm Airgap Intake did not have the passage.
As to diesel there are 3 ways to slow with the motor .
1) Engine Braking. Just let off the throttle.
Same as a gas but less effective.
2) Ehxsost Brake. The flap in the ehxsost. On my Cummins this up grade requires up-graded ehxsost valve springs 60# vs stock 30# to hold the valves closed on the intake stroke. Exced 60psi on the brake and it will still over ride the spring.
.. Cummins,Duramax, Ford use option 2 by way of the VGT Turbo closing the vains enuph to act like this type.
3) Jake Brake . A device that prevents the ehxsost valves from opening, normally multi stage in pairs 180° out .
... 6.7 Cummins has a kit avaliable. Its the only small US diesel I'm currently aware of with this Big truck technology.
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
![](http://ecomodder.com/forum/fe-graphs/sig8842a.png)
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
