Old 12-27-2016, 02:15 PM   #55 (permalink)
aerohead
will it matter
Originally Posted by whatmaycome14 View Post
Yes, but if the radiator is fully ducted, will it matter if it is not on the centerline of the hood and instead offset to the drivers side of the car by 10in? OR if is only on half the width of the radiator?
If the inlet duct is airtight,the static pressure differential across the heat-exchanger matrix will induce the flow.Some 1/4-inch hardware cloth ahead of the radiator could help distribute the turbulent air more evenly across the core if the air was attempting to hug one side.
Ideally.you'd have a gentle,divergence.
