Old 12-29-2016, 04:30 PM   #4 (permalink)
RustyLugNut
Like Oil_Pan_4 pointed out, there are no cheap solutions to this. However, if you tune to lambda=1 using a wide band O2 sensor, you are most of the way home for HC, CO and NOx. I still use an old Hawk tester with CO and HC measurements. You can occasionally find these used on Ebay for a few hundred USD. But, I think they are over kill for the DIY.
