Old 12-30-2016, 12:23 PM   #61 (permalink)
gumby79
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
90 day: 23.4 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 2×4 AUTO
Pickups
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
90 day: 20.24 mpg (US)
Jona Allison aero - '91 Dodge Ram D-250 Le
90 day: 20.76 mpg (US)
This article
Undertrays, Spoiler & Bonnet Vents, Part 3
Designing, siting, installing and testing bonnet vents
by Julian Edgar
Sorce: AutoSpeed - Technology, Efficiency, Performance
Details how to find the ideal spot to place your vent. How to determine if you are getting the desired effect. As stated its all about the pressure Vs lack there of.
This graph shows the pressure differential ( fore and aft of the intercooler) results of several of the mods that you are trying to design.
Your goal is to find the purple spot in the next pic. For your exit. And the red on tbe front for the intake.
The magic of a "good" ecm tuner/ carb. tuner is the ability to adjust for today's up to the minute environmental conditions. This magical skill is able to be simplified when you eliminate some of the variables. The variable I am referring to is the IAT just pulling fresh air or just under "sealed" hood require a wide tuning map . Pulling both through a mixing valve will allow the smallest tuning window. AKA the most efficient.
OilPan has shown that a gen set non-intercooled is supposed to pull intake air from inside the enclosure below 20°f . As this is outside the tuning parameters. Aka a significant loss of efficiency is seen below this pre turbo IAT caused by a change in air density.
Gumby Stay Flexible
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
The Following User Says Thank You to gumby79 For This Useful Post:
ECONORAM (01-03-2017)
