Old 01-02-2017, 11:32 AM   #20 (permalink)
pgfpro
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
On my car at idle I save only 2% going from 14.7:1 A/F to lean burn 20:1 A/F.
At idle I can't run any leaner do to the lack of turbulence in air flow.
At 55mph I save 29% going from 14.7:1 A/F to 33:1 A/F. Plus the amount of fuel weight used at 55 mph compared to idle is massive.
My best savings at idle is when I shut the engine off. So I turn my engine off a lot instead of having it burn fuel at idle.
Pressure Gradient Force
The Positive Side of the Number Line
