Old 01-02-2017, 02:56 PM   #29 (permalink)
sallen
VW GOLF - '96 Volkwagen Golf MK3 GL
90 day: 50.21 mpg (US)
Commute scoot - '95 Suzuki AE50 Style
Last 3: 70.4 mpg (US)
The German - '99 Mercedes W202 C200 Classic
90 day: 27.65 mpg (US)
Here you go,
I used the flow rate spreadsheet from the MPGuino wiki to calculate my ms/gal. My injectors are 22lb/hr (which as an aside - google says is 166ml/min, but the spreadsheet says is 231.3 cc/min and I thought cc and ml were interchangeble 1:1).
The attached image shows the uSec/gal figure I'm using, which is returning a believable instant MPG of around 20-50mpg at cruising speed depending on throttle position. - As another aside, before the 64 bit bug was fixed, and before I tried to "fix" it by using a UK MPG conversion figure the same length and the US one - the instant figure was similarly crazy low like the Current and Tank are now. Maybe they are expecting a number with more decimal places to work with?
The image also shows Current and Tank (which jumped from around 3mpg straight to 0 about 5-10miles ago and has stayed there).
Hope this helps.
Will you recoup money spent on mods in fuel saved? see my spreadsheets here
