Old 01-03-2017, 02:18 PM   #2932 (permalink)
MPaulHolmes
PaulH
MPaulHolmes's Avatar
oh good that shouldn't damage anything important. You can just add a jumper across the fuse. Are you sure the pinout for your current sensor cable is right? Orient the board so that the 3 current sensor plugs are along the bottom. The rightmost pin of all 3 is the output of the current sensor. It should be 2.5v when there's no current going through them. Do you have 3 current sensors plugged in? You can measure the 2.5v relative to the GND test point.
Yes, could you email me, because I'm having trouble finding your email. My email is paulandsabrinasevstuff@gmail.com. I'll then send all the pcb and sch files, as well as a pdf showing pinouts of everything.
kits and boards
The Following 2 Users Say Thank You to MPaulHolmes For This Useful Post:
motorulf (01-03-2017), thingstodo (01-03-2017)
