Old 01-03-2017, 03:12 PM   #2935 (permalink)
motorulf
motorulf's Avatar
True
I suspect that the commands over the serial port are supposed to be self-explanatory.
Well, not for me...
For example
stream-raw-throttle xxx (range 0-1)
I just type in stream-raw-throttle and get a stream of raw throttle data?
Nothing is happening. None of the stream commands works for me.
Tried the run-pi-test & run-rotor-test commands also. Nothing.
I managed to change motor type and throttle type, so something is working.
What am i doing wrong this time?
Can i use an encoder without an index pin?
The motor that i have connected now does not have one.
