Old 01-03-2017, 07:40 PM   #2940 (permalink)
MPaulHolmes
PaulH
MPaulHolmes's Avatar
The default is a hall effect throttle, so the soldered resistors are set up for that. It won't work for a resistive throttle without an addition of a resistor, and changing another resistor. That's the problem you are having. You need to change:
R101 should be like 2k (instead of nothing).
R73 should be like 4.7k instead of 47k (I think it's 47k right now).
For a Lem Hass 200-s, the current sensor amps per volt is 200amp / 0.625v = 320
kits and boards
The Following 2 Users Say Thank You to MPaulHolmes For This Useful Post:
motorulf (01-04-2017), thingstodo (01-03-2017)
