Old 01-04-2017, 02:47 PM   #2948 (permalink)
motorulf
motorulf's Avatar
I had apparently mixed up the cables when i checked and fixed the pinout.
no 1 was going to 2 and vice versa.
Now things work better.
It does not run wild and i managed to complete a successful run-pi-test.
I saved
Then i tried run-pi-test2. now it is consuming 60Amps again. rotor vibrating and my thinner "fuse" cables melting. I aborted (cut the power to everything)
I tried to power everything up again, when the contactor closes the motor starts vibrating and humming again, drawing 60 amps.
All the current sensors have connectors pointing towards the IGBT end of the cable.
Going forward though
Yeah, i am only using 25 volts right now, is that too low?
