jthistle -
I can't agree more. Getting the built-in turn signals is another coup in my book (and they look cool too). I like where you're going
Question: This is a 100% solvable (non?-)problem, but would you have to worry about the voltage differences between a motorcycle and a car? My circa 1970's motorcycle used a 6 volt battery.
Answer: Nevermind. I just Googled, and it looks like a non-issue because the Hayabusa also uses a 12 volt battery :
Suzuki TL1000R Motorcycle Battery by Power SourceŽ Model #WP12A-BS - SUZUKI Motorcylce & ATV Batteries - Powerstride Battery
Compatible with Suzuki motorcycle models GSX1300/GSX1300R Hayabusa (1999-2005), GSX-R1000 (2005-2006), TL1000R (1998-2003), GSX-R750 (2000-2005), SV650 (1999-2002)
Volts: 12
CCA: 175
Ahr: 9.5
CarloSW2
