Old 01-05-2017, 02:12 PM   #141 (permalink)
rmay635703
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
The volt is designed to handle fuel & engine maintenance automatically.
When the engine has not been used for a period of time EMM will run no activity required on your part.
There is no need to actively do it yourself and if you used premium gas it's good for a year, then the volt burns it all off automatically.
If you aren't going to use a tank full of gas in a year, use it how you wish but leave a quarter of a tank for FMM and annual burn off.
Then when needed add the smallest amount of fuel needed to kill the engine maintenance.
Obviously no need for a full tank if you can't use it.
Many threads on GM-volt on this matter
The Following User Says Thank You to rmay635703 For This Useful Post:
Daox (01-05-2017)
