Old 01-05-2017, 01:23 PM   #7147 (permalink)
mora
Golfwagen - '89 Volkswagen Golf mk2
90 day: 107.14 mpg (US)
And change firmware too.
This is found from JackBauer's instruction:
remove R10 and replace R8 and D1 with wire links. Pin 5 now outputs a +5v supply for the pedal and pin 4 is now the input from the pedal. Ground can be connected to pin 2. Just a case of disconnecting the traction supply and using RTD to setup the range.
