No.
I will not send low voltage to items made to have 13.6volts... run a fuel pump that is rated to get full voltage, and run it at say 12.2v, amperage goes up, along with heat and early failure. I want the computer and air bags to always have full voltage as well.
Paralleling the batteries only prolongs my low voltage.
I will have a selenoid to jump the batteries together, so if I WANT to, I can either jump start myself, or charge the deepcycle from the alternator if I so desired.
I wish I had pictures of my old minivan from years ago..... looked like a cockpit.
