Old 01-07-2017, 08:32 PM   #8 (permalink)
bandit86
Buggie - '01 Vw Beetle TDI Gls
Experiment. 1 liter diesel to a 75 liter tank makes high octane gas. Run5, or more. When you start to see white smoke, back off. 10 percent should not be a problem. I have run 10 percent gasoline in my common rail diesel dodge in the summer. I can do more in winter. It runs really good on a 10 percent oil and 5 percent gasoline concoction. I need to play. With timing, it is fully advanced, I could probably run better with lower timing and more gasoline.
