Hi t vago
It's great I had no idea it worked like that.
One change that I believe takes some confusion is in InjSize mL/min which could have an InjFlow text and use cc/min which seems to be more common in the specs of the injectors, what do you think.
Another question, the InjSize mL/min does not allow a decimal number in my case, the injector has a value of 191.8 cc/min, I have to put "192" correct.
Originally Posted by t vago
value = value * 1000000 microseconds/sec
I think you mean microseconds/USGal
Thanks
José Rodrigues
