teoman
5.2.12 No streamlining may be attached to the rider.
freethink. 1) Move your transponder somewhere else. Maybe behind the gauge cluster. You still want it as far forward as possible, in case you are neck and neck with somebody at the finish line.
A
5.4..2.....The ESU is considered to be properly mounted if it is securely fastened to the right front fork leg, right front fork tube or right side of fairing where the signal can be read by the ground antenna and activated by passing through the activation area..It is the riders responsibility to insure proper activation of the ESU before entering the racecourse.
5.4.2.A. There can be no solid metal or carbon fiber between the mounted ESU and the ground antenna......
Michael Moore: ower your head and try and get your back as horizontal as possible.
A
Permalink#18
As for the helmet and leathers, I really can't modify them per rules. With my chest slammed against the tank, that helmet position is my maximum upward look (actually takes a lot of effort). I am trying to get an unpadded race seat, which should lower my pelvis an inch or more into the bike- as the rest of my body follows, I might get those extra degrees clockwise rotation of the helmet that you recommended.
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
