Old 01-12-2017, 08:37 PM   #31 (permalink)
redpoint5
90 day: 38.47 mpg (US)
I wouldn't want to tilt a radiator unless it was designed to be installed at that angle. In other words, the fins are lined up to pass air straight through at the installed angle. Otherwise, the fins are not at optimal angle, not cooling as efficiently as they could, and creating higher air pressure in front of the radiator. In Australia, I would think it is important to get full cooling capacity out of the radiator.
The Following 2 Users Say Thank You to redpoint5 For This Useful Post:
craysus (01-12-2017), Xist (01-13-2017)
