Old 01-12-2017, 09:08 PM   #114 (permalink)
racprops
THAT is what I want to do vaporizer 100% of the gasoline on the spot.
Low temp vapor will leave gunk behind, IF you run a whole tank though and only burn off the light stuff you get garbage back into the tank.
For this to work I need high temps to burn all the junk in the gas. And put nothing back into the tank.
Rich
