Most engine builders will not put together engines for daily driver engines with total seal rings because of complaints about burning oil and high oil consumption.
Also it's been found that most of the rings will line up and stay lined up after as few as 30,000 even on a V8 engine.
In a diesel engine you won't have cylinder vacuum pulling oil through the ring gaps but when the gaps line up you can forget about all that cold compression you had.
Also the total seal ring reviews leave something to be desired. Most people saying that they are not worth the added cost and that next time they will just use traditional file fit rings.
Based on that I'm not putting them on any on road engine I build. I thought about using them on my 6.5L diesel and I'm really glad I didn't.
