Old 08-13-2008, 09:05 PM   #29 (permalink)
SickMPGs
Crappy Gas Pipe - '84 Mercedes 300D Turbo 230k Miles
Originally Posted by Bullockracing View Post
A shiny car will get better mileage... The reference to the NASCAR cars triggered a special I saw where they talked about using skins instead of decals on the bodies of the NASCAR cars. This would be similar to removing all of the little emblems on the car to smooth out the surface. Also, in WWII, the USAAC discovered that there was significant drag associated with the olive drab painted aircraft, and that by removing the drab paint and leaving the bare metal, they not only saved some weight, but big gains were the reduced drag on the plane.
The Americas Cup was lost to the Aussies after they applied "Ripplets" to their hull. These triangular shaped bumbs would produce a back eddie to push the boat forward. Not sure if it would work on a car
