Hi t vago
Originally Posted by t vago
I did make a couple of corrections. One was with the labels on your microseconds/gal section, and the other was with your SI correction factor section.
Thank you for the correction.
This new version also has the same problem, the compilation is done without errors when it starts to send it is slow and does not send.
This is the information it shows.
Code:
Arduino: 1.8.0 (Windows 10), Placa:"Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
E:\arduino-1.8.0-windows\arduino-1.8.0\arduino-builder -dump-prefs -logger=machine -hardware E:\arduino-1.8.0-windows\arduino-1.8.0\hardware -tools E:\arduino-1.8.0-windows\arduino-1.8.0\tools-builder -tools E:\arduino-1.8.0-windows\arduino-1.8.0\hardware\tools\avr -built-in-libraries E:\arduino-1.8.0-windows\arduino-1.8.0\libraries -libraries C:\Users\josem\OneDrive\Documentos\Arduino\libraries -fqbn=arduino:avr:mega:cpu=atmega2560 -vid-pid=0X2341_0X0042 -ide-version=10800 -build-path C:\Users\josem\AppData\Local\Temp\arduino_build_882241 -warnings=none -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=E:\arduino-1.8.0-windows\arduino-1.8.0\hardware\tools\avr -prefs=runtime.tools.avrdude.path=E:\arduino-1.8.0-windows\arduino-1.8.0\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=E:\arduino-1.8.0-windows\arduino-1.8.0\hardware\tools\avr -verbose C:\Users\josem\Desktop\MPGuino.ino\MPGuino.ino.ino
E:\arduino-1.8.0-windows\arduino-1.8.0\arduino-builder -compile -logger=machine -hardware E:\arduino-1.8.0-windows\arduino-1.8.0\hardware -tools E:\arduino-1.8.0-windows\arduino-1.8.0\tools-builder -tools E:\arduino-1.8.0-windows\arduino-1.8.0\hardware\tools\avr -built-in-libraries E:\arduino-1.8.0-windows\arduino-1.8.0\libraries -libraries C:\Users\josem\OneDrive\Documentos\Arduino\libraries -fqbn=arduino:avr:mega:cpu=atmega2560 -vid-pid=0X2341_0X0042 -ide-version=10800 -build-path C:\Users\josem\AppData\Local\Temp\arduino_build_882241 -warnings=none -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=E:\arduino-1.8.0-windows\arduino-1.8.0\hardware\tools\avr -prefs=runtime.tools.avrdude.path=E:\arduino-1.8.0-windows\arduino-1.8.0\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=E:\arduino-1.8.0-windows\arduino-1.8.0\hardware\tools\avr -verbose C:\Users\josem\Desktop\MPGuino.ino\MPGuino.ino.ino
Using board 'mega' from platform in folder: E:\arduino-1.8.0-windows\arduino-1.8.0\hardware\arduino\avr
Using core 'arduino' from platform in folder: E:\arduino-1.8.0-windows\arduino-1.8.0\hardware\arduino\avr
Detecting libraries used...
"E:\arduino-1.8.0-windows\arduino-1.8.0\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10800 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IE:\arduino-1.8.0-windows\arduino-1.8.0\hardware\arduino\avr\cores\arduino" "-IE:\arduino-1.8.0-windows\arduino-1.8.0\hardware\arduino\avr\variants\mega" "C:\Users\josem\AppData\Local\Temp\arduino_build_882241\sketch\MPGuino.ino.ino.cpp" -o "nul"
Generating function prototypes...
"E:\arduino-1.8.0-windows\arduino-1.8.0\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10800 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IE:\arduino-1.8.0-windows\arduino-1.8.0\hardware\arduino\avr\cores\arduino" "-IE:\arduino-1.8.0-windows\arduino-1.8.0\hardware\arduino\avr\variants\mega" "C:\Users\josem\AppData\Local\Temp\arduino_build_882241\sketch\MPGuino.ino.ino.cpp" -o "C:\Users\josem\AppData\Local\Temp\arduino_build_882241\preproc\ctags_target_for_gcc_minus_e.cpp"
"E:\arduino-1.8.0-windows\arduino-1.8.0\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\josem\AppData\Local\Temp\arduino_build_882241\preproc\ctags_target_for_gcc_minus_e.cpp"
A compilar o rascunho...
"E:\arduino-1.8.0-windows\arduino-1.8.0\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10800 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IE:\arduino-1.8.0-windows\arduino-1.8.0\hardware\arduino\avr\cores\arduino" "-IE:\arduino-1.8.0-windows\arduino-1.8.0\hardware\arduino\avr\variants\mega" "C:\Users\josem\AppData\Local\Temp\arduino_build_882241\sketch\MPGuino.ino.ino.cpp" -o "C:\Users\josem\AppData\Local\Temp\arduino_build_882241\sketch\MPGuino.ino.ino.cpp.o"
Compiling libraries...
Compiling core...
A usar o ficheiro previamente compilado: C:\Users\josem\AppData\Local\Temp\arduino_build_882241\core\wiring_pulse.S.o
A usar o ficheiro previamente compilado: C:\Users\josem\AppData\Local\Temp\arduino_build_882241\core\WInterrupts.c.o
A usar o ficheiro previamente compilado: C:\Users\josem\AppData\Local\Temp\arduino_build_882241\core\hooks.c.o
A usar o ficheiro previamente compilado: C:\Users\josem\AppData\Local\Temp\arduino_build_882241\core\wiring.c.o
A usar o ficheiro previamente compilado: C:\Users\josem\AppData\Local\Temp\arduino_build_882241\core\wiring_analog.c.o
A usar o ficheiro previamente compilado: C:\Users\josem\AppData\Local\Temp\arduino_build_882241\core\wiring_digital.c.o
A usar o ficheiro previamente compilado: C:\Users\josem\AppData\Local\Temp\arduino_build_882241\core\wiring_pulse.c.o
A usar o ficheiro previamente compilado: C:\Users\josem\AppData\Local\Temp\arduino_build_882241\core\wiring_shift.c.o
A usar o ficheiro previamente compilado: C:\Users\josem\AppData\Local\Temp\arduino_build_882241\core\CDC.cpp.o
A usar o ficheiro previamente compilado: C:\Users\josem\AppData\Local\Temp\arduino_build_882241\core\HardwareSerial.cpp.o
A usar o ficheiro previamente compilado: C:\Users\josem\AppData\Local\Temp\arduino_build_882241\core\HardwareSerial0.cpp.o
A usar o ficheiro previamente compilado: C:\Users\josem\AppData\Local\Temp\arduino_build_882241\core\HardwareSerial1.cpp.o
A usar o ficheiro previamente compilado: C:\Users\josem\AppData\Local\Temp\arduino_build_882241\core\HardwareSerial2.cpp.o
A usar o ficheiro previamente compilado: C:\Users\josem\AppData\Local\Temp\arduino_build_882241\core\HardwareSerial3.cpp.o
A usar o ficheiro previamente compilado: C:\Users\josem\AppData\Local\Temp\arduino_build_882241\core\IPAddress.cpp.o
A usar o ficheiro previamente compilado: C:\Users\josem\AppData\Local\Temp\arduino_build_882241\core\PluggableUSB.cpp.o
A usar o ficheiro previamente compilado: C:\Users\josem\AppData\Local\Temp\arduino_build_882241\core\Print.cpp.o
A usar o ficheiro previamente compilado: C:\Users\josem\AppData\Local\Temp\arduino_build_882241\core\Stream.cpp.o
A usar o ficheiro previamente compilado: C:\Users\josem\AppData\Local\Temp\arduino_build_882241\core\Tone.cpp.o
A usar o ficheiro previamente compilado: C:\Users\josem\AppData\Local\Temp\arduino_build_882241\core\USBCore.cpp.o
A usar o ficheiro previamente compilado: C:\Users\josem\AppData\Local\Temp\arduino_build_882241\core\WMath.cpp.o
A usar o ficheiro previamente compilado: C:\Users\josem\AppData\Local\Temp\arduino_build_882241\core\WString.cpp.o
A usar o ficheiro previamente compilado: C:\Users\josem\AppData\Local\Temp\arduino_build_882241\core\abi.cpp.o
A usar o ficheiro previamente compilado: C:\Users\josem\AppData\Local\Temp\arduino_build_882241\core\main.cpp.o
A usar o ficheiro previamente compilado: C:\Users\josem\AppData\Local\Temp\arduino_build_882241\core\new.cpp.o
A usar o ficheiro previamente compilado: C:\Users\josem\AppData\Local\Temp\arduino_build_882241\core\core.a
Linking everything together...
"E:\arduino-1.8.0-windows\arduino-1.8.0\hardware\tools\avr/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections,--relax -mmcu=atmega2560 -o "C:\Users\josem\AppData\Local\Temp\arduino_build_882241/MPGuino.ino.ino.elf" "C:\Users\josem\AppData\Local\Temp\arduino_build_882241\sketch\MPGuino.ino.ino.cpp.o" "C:\Users\josem\AppData\Local\Temp\arduino_build_882241/core\core.a" "-LC:\Users\josem\AppData\Local\Temp\arduino_build_882241" -lm
"E:\arduino-1.8.0-windows\arduino-1.8.0\hardware\tools\avr/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\Users\josem\AppData\Local\Temp\arduino_build_882241/MPGuino.ino.ino.elf" "C:\Users\josem\AppData\Local\Temp\arduino_build_882241/MPGuino.ino.ino.eep"
"E:\arduino-1.8.0-windows\arduino-1.8.0\hardware\tools\avr/bin/avr-objcopy" -O ihex -R .eeprom "C:\Users\josem\AppData\Local\Temp\arduino_build_882241/MPGuino.ino.ino.elf" "C:\Users\josem\AppData\Local\Temp\arduino_build_882241/MPGuino.ino.ino.hex"
O rascunho usa 22174 bytes (8%) do espaço de armazenamento do programa. O máximo é 253952 bytes.
Variáveis globais usam 1286 bytes (15%) de memória dinâmica, restando 6906 bytes para variáveis locais. O maximo é 8192 bytes.
E:\arduino-1.8.0-windows\arduino-1.8.0\hardware\tools\avr/bin/avrdude -CE:\arduino-1.8.0-windows\arduino-1.8.0\hardware\tools\avr/etc/avrdude.conf -v -patmega2560 -cwiring -PCOM4 -b115200 -D -Uflash:w:C:\Users\josem\AppData\Local\Temp\arduino_build_882241/MPGuino.ino.ino.hex:i
avrdude: Version 6.3, compiled on Dec 16 2016 at 13:33:19
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "E:\arduino-1.8.0-windows\arduino-1.8.0\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM4
Using Programmer : wiring
Overriding Baud Rate : 115200
AVR Part : ATmega2560
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PA0
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 10 8 0 no 4096 8 0 9000 9000 0x00 0x00
flash 65 10 256 0 yes 262144 256 1024 4500 4500 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : Wiring
Description : Wiring
Programmer Model: AVRISP
Hardware Version: 15
Firmware Version Master : 2.10
Vtarget : 0.0 V
SCK period : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.01s
avrdude: Device signature = 0x1e9801 (probably m2560)
avrdude: reading input file "C:\Users\josem\AppData\Local\Temp\arduino_build_882241/MPGuino.ino.ino.hex"
avrdude: writing flash (22174 bytes):
Writing | #####avrdude: stk500v2_ReceiveMessage(): timeout
avrdude: stk500v2_getsync(): timeout communicating with programmer
avrdude: stk500v2_command(): failed miserably to execute command 0x13
avrdude: stk500v2_paged_write: write command failed
Ocorreu um erro a enviar o rascunho
Thanks
José Rodrigues
