I thought it was pretty settled that the coolant warms up faster than the oil. Water is a much better thermal conductor than oil, and it flows through higher-temperature parts of the engine than the oil.
So that heat exchanger should get to function as both an oil warmer
and an oil cooler, just at different stages.
(I'll welcome corrections if wrong.)
