Thank you for the reply.
What pressure do you recommend for the EV14 injectors?
I found the following which are relatively cheap and come in a pack of 4. Has 12 holes in the nozzle (not sure what kind of an advantage that is) and most of all they are E85 compatible.
https://www.aliexpress.com/item/4-12holes-High-quality-performance-550cc-fuel-injector-for-G-M-C-FORD-chevrolet-replace-for/32720736959.html?spm=2114.01010208.3.18.y79sd4&ws_ ab_test=searchweb0_0,searchweb201602_5_10065_10068 _10000009_10084_10083_10080_10082_10081_10110_1011 1_10112_10060_10113_10114_10062_10056_10055_10054_ 10059_10099_10078_10079_10000012_10103_10073_10102 _10000015_10096_10000018_10052_10053_10107_10050_1 0106_10051,searchweb201603_9,afswitch_5,single_sor t_3_default&btsid=d375f673-52e7-4896-8a20-26a4082f8f37
