Thanks for the heads up on the OBD2. I do not have a scanner yet, wonder if the arduino is capable enough for serving both functions.
Also any idea of the different nozzle types on these injectors?
And how did you get the hose attached to the nozzle?
There are also these types of nozzles (or nozzle less?)
https://www.aliexpress.com/item/Top-feed-High-flow-performance-Standard-48mm-ev14-650cc-60lbs-E85-fuel-injector-High-impedance-Flow/32774687237.html?spm=2114.01010208.3.42.y79sd4&ws_ ab_test=searchweb0_0,searchweb201602_5_10065_10068 _10000009_10084_10083_10080_10082_10081_10110_1011 1_10112_10060_10113_10114_10062_10056_10055_10054_ 10059_10099_10078_10079_10000012_10103_10073_10102 _10000015_10096_10000018_10052_10053_10107_10050_1 0106_10051,searchweb201603_9,afswitch_5,single_sor t_3_default&btsid=d375f673-52e7-4896-8a20-26a4082f8f37
