Old 01-13-2017, 05:30 PM   #10 (permalink)
teoman
teoman's Avatar
A3 - '12 Audi A3
They say that you should only be injecting %20 of the fuel max.
At 1000ml/min, will be enough for 5000ml/min -> 300.000 ml/h. -> 300L /h
That is quite an amount of water!
Also how did you pulse the injector? Using the standard PWM function? If so did you lower the frequency?
