Hi t vago
This new version holds the error.
Your procedure is the same as mine, the only differences are in the LCD selection and buttons your selection is different, one thing that is also different and may justify the problem is that I use the Arduino Mega without anything connected only with the USB cable, it is only speculation but what you have connected do not let the arduino fall asleep and allow to complete the recording.
Because this problem only started after infusing deep sleep into the code I think that's the problem.
Thanks
José Rodrigues
