Originally Posted by racprops
THAT is what I want to do vaporizer 100% of the gasoline on the spot.
Low temp vapor will leave gunk behind, IF you run a whole tank though and only burn off the light stuff you get garbage back into the tank.
For this to work I need high temps to burn all the junk in the gas. And put nothing back into the tank.
Rich
you don't need 800 degrees to do it. your goal and the end should be a white vapor.. or if you go one step higher Plasma state .. you will need to strip electrons and excite the Protons to a state of implosion to make it happen
