Old 01-16-2017, 10:35 AM   #91 (permalink)
Daox
According to what I've seen, the thermostat opens up at 197F. So, I plan to leave the grill block closed until about 206F, and then close it once the temperature drops to about 197ish. I'm sure it'll require some tweaking. This will just be initial programming to get things running and test it out.
The Following User Says Thank You to Daox For This Useful Post:
BamZipPow (01-16-2017)
