Thread: Wood gas?
Old 01-16-2017, 02:45 PM   #60 (permalink)
freebeard
Dunn-Right Incorporated
Home of the "Volks-Air" Air Compressor
"When it has to be Dunn-Right"
Instead of cutting down the engine, do a Dunn-Right air compressor conversion. Add a 60 gallon compressed air tank, twinned alternators and a battery bank.
Wherever you go, you are the local utility company.
Use hemp oil lubricants.
Edit: Why I like this idea: It ties the vehicle to specific functions, but if you had the air tank and batteries between the driver and rear axle, then you could have a 4ft tall tool chest behind the axle that could drop down onto it's own casters. They you'd have a shop truck that you could drive indoors on compressed air.
Instead of an APE or Cushman, I'd want a fiberglass Ed Roth tricycle body. Maybe a C-cab. Here's an (admittedly rear-) Ed Roth VW engine:
http://justacarguy.blogspot.com/2012/04/ed-big-daddy-roth-tribute-trike-and.html
